Incredibly affordable MMWave Radar Sensor with almost instant presence reaction time. It also opens up the opportunity to extend your Zigbee network by serving as an additional router đđđ.
Using the affiliate links below helps support the channel and all the content I create đđ
Overview#
ZY-M100 Mmwave Radar Sensor
Holder Stand Adjustable:
- Aliexpress: (here)
Stand to 3D-print:
- Printables: (here)
How to integrate it in Home Assistant#
You can use this button to be redirected to you Home Assistant instance to add the device to your Zigbee network.
Enable New Variants Full ZHA Support#
First create folder custom_zha_quirks
, then create file ts0601_radar.py
and paste the code from the supported variant that you need.
If you need more than one variant, you can create multiple files with different names.
List of supported variants
- _TZE200_ar0slwnd
- _TZE200_sfiy5tfs
- _TZE200_mrf6vtua
- _TZE200_ztc6ggyl
- _TZE204_ztc6ggyl
- _TZE204_sxm7l9xa
- _TZE204_qasjif9e #new
You can find the code here
Configuration sliders in miliseconds, 1 second = 1000 miliseconds.
- _TZE204_e5m9c5hl #new
- _TZE204_ijxvkhd0 #new
Configuration sliders in seconds.
- _TZE204_yensya2c #new
Then you can add this to your configuration.yaml
file.
homeassistant/configuration.yaml
zha:
custom_quirks_path: /config/custom_zha_quirks/
Recommended Starting Settings#
Fading time:
BELOW 65000 miliseconds (-65 sec): The unit only detects large / faster motion, ignoring micro motions.
ABOVE 65000 miliseconds (+65 sec): It detects micro motions in the central cone, like breathing etc.
Illuminance Sensor fix#
Via Reddit
Blueprint#
đĄđˇ Sensor Light
I would love to hear your comments, or suggestions on this post.
Fixt is a Software Engineer passionate about making the world a better place through technology and automation.
